Amp Question
  • 2
Depends on what kind of power the sub needs, but simple answer is yes, at 3 ohms.
My friend has a JL W7 and his amp bit the dust so we were wondering if it would run fine off of my amp? I think the W7 is like 1500 rms, correct me if I'm wrong.
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
Haven't 100% landed on which one, but I am down to those two
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
03Bonneville
03Bonneville
Lincoln, NE
03Bonneville
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
