1/2" MDF for dual 10" sub box?
its harder to work with if your using screws. .75 is like $5 more/sheet. why you wanna go with .5?
Well I've already made the box. But if I need to build a different one I want to do that before I install it. I've silliconed, glued and screwed it together, it looks pretty stable.
did you use any bracing? is it ported or sealed? U may be ok with low powered subs.
install the drivers and crank it up and see whaqts up
I haven't braced it any, its sealed and the subs are only 150rms so there really not that high powered.
photostream
Because i can add more support to it, but it will take some time and money to do so. I didn't want to destroy the box if i can just add more support first, but only if needed.
If it is built properly you will not destroy it, even if it is .5".
You can always add the 1/2 wood on top,to make it thicker/add a new Face to it so to speak,Those subs will get down in a well made box.Though they are entry level subs, I had a pair of tens on an Autotek Mean Machine 99, and in 1.4cu ft ea sealed, and they sounded pretty good
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
901
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
Yes Should be easy with a flush trim bit in a router and will allow OP to hide any screws/nails used along edges.
Logan Miller
Logan Miller
Louisiana
audiobaun
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
