Polk MM6501 or JBL MS-62C or Polk DXi6500?
  • 4
I've had both, and absolutely loved those polks, but I just half assed installed the jbl's (still gotta improve the mounting and deaden the doors and tweak the settings), and the jbl's are a whole different speaker upon my first impressions and my limited listening time. They are extremely accurate, Cymbals sound lifelike like I've only heard in much more expensive sets. Midbass is decent considering the lousy install, so not fair to compare yet.
If I were to choose again, I'd definitely go JBL.
Ok so if i get the JBL MS-62C what speakers do I get in the back. Does JBL make speakers that are meant to go with these?
JBL has several lines of speakers and a variety of coaxials that would be great with MS-62C components in the front. You don't need to match the speakers and they don't make MS coaxials. Here's a nice choice if you have 6.5s in the rear:GTO628
Infinity Kappas can be considered close to MS-62C, as the Kappa use a similar woven glass fiber material for the cones. Of course, they're not the same in general as the tweeters and crossovers are still very different. Kappas use first order crossover, I believe, and silk tweeter. JBLs use a metal tweeter with a more robust crossover. I'd agree that the rear speakers probably don't matter a lot. I personally would use Hybrid Audio Mirus coaxial speakers (paper come and silk tweeter, with a primitive crossover typical of coaxial speakers).
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
819
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
4K
Xboxhacka
Xboxhacka
Bentonville, Ar
Xboxhacka
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
Latest topics
