WTT: Blown SHOK II Amp & RF HX2 POWER 12" Mint.
AcuraTL03
;)looking for korean made solid 3k rms @ 2ohms or .5ohms.
newer style AQ 3500.1d, sundown amps crescendo. etc. could add cash if need be.
the HX2 is like new barely used, no spider sagging at all. as you can see in the pictures. dual 2ohm
the area inside the green circle show no sign of damage.
inside the Red are blown resistors.
and the yellow is a blown cap.
im not so fimiliar with amps and amp parts i just know a little from my job. so i could be wrong. so refer to pictures.
It dont work that way.
this isnt an auction site we dont need to get into bidding wars list a price or 1 of 2 things.will likely happen its honna get closed by a moderator
Or you can expect lowball offers....
Ill offer you 5$
Ill offer you 5$
so can i report you for post dumping
whats the amp rated for 2k@1ohm?
Output Power (RMS)12v Power
4ohm 500w
2ohm 1000w
1ohm 2000w
Strapped Output (RMS) 12v Power
2ohm 4000w
Frequency Response: 15hz – 270hz Damping factor: 200
Input Sensitivity: 6v-0.2v
Low Pass Filter: 35hz – 250hz
Subsonic Filter: 10hz – 50hz
Bass Boost: 0-9db
Phase Shift: 0 – 180°
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
848
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
AcuraTL03
AcuraTL03
Laveen, Arizona
AcuraTL03
1aespinoza
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
Latest topics
