component wiring ?
jcraft
Hi All,
Another component question. JUst getting info to see which is the best way to wire. BOught som Infinity reference 6030Cs ones for front. They have a crossover so basically I was going to run both channels from 50x4 amp one to each crossover then run the woofer and tweet to each crossover. The other two channels will be for rear. Now I am hearing people wire there tweets and mids to each channel and power the rears from the HU. Not sure how to wire that and if it would be better in my aplication. JI am assuming I need the croosover though. I have a Sony HU that has equalizer settings and the amp I have is locked in at a HPF of 80hz which can't be changed. IF any of you think this is a better hookup, please advise how you wire all to separate channels and still use the crossovers. Thanks
I would personally run it the first way you said, with the component sets using only the front 2 channels because in order to run the tweeter and front speakers on 4 separate channels Im pretty sure you would need 4 separate crossovers, plus I think overall doing it this way it will be louder and most likely sound better.
when I ran Rear fill off HU power it just sounded kind of empty back there
agreed, your amp and HU are not capable of wiring woofers and tweeters separately.
what i would do, and one thing you can try is bridging your amp to the front components and running the rears off the HU. this also requires you use your fader to fade to front to attenuate the rears to give you more head unit volume range.
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
The first two screws (IN+ IN-) go to the amp/radio. Second pair of screws (W+ W-) go to the woofer. Third pair of screws (T+ T-) go to the tweeter.
839
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
672
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
758
jcraft
jcraft
buffalo new york
keep_hope_alive
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
