Advice on HU power 6x9
If he ever plans on amping them Neo then I'd suggest some of which you posted. But he's using a h/u that puts out
Ehh fair enough and apparently I skimmed right over the factory radio part.
OP, you'd probably see more gains just from amplifying your speakers rather than replacing them. Try that first, then revisit replacing your 6x9s
I think he should go with the Lanzar off of the HU power, and get funds up to do a very nice install for amped speakers,and a single sub set up,and not waste money on good expensive quality speakers that will more than likely get clipped to death from distortion.Keep it simple I say, till you get the funds for a entry level set up.I think you will be surprised what the Lanzars can produce for you for your money.Just my 2cents
195
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
382
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
332
Also use the Orange wire. It will be constant 12v. Yes, you can bi-amp your co-axials. You just separate the tweeter wires ftom the terminals and...
duckfart
duckfart
Long Beach, CA
Sleeklsc
ttt123
    Apr 16, 2024
ttt123
    Apr 16, 2024
