Jump to content
Sign in to follow this
k_schutte
bandpass through rear deck
Recommended Posts
I am going to be redoing my box here before too long and thought about going with a bandpass ported through the rear deck. I had a factory 10" in the rear deck so there is a nice open space anyways. I have a pair of RE s-e-x 10"s getting about 800~ watts rms each.
I haven't seen any bandpass/trunk builds so I was wondering if anyone has experience here? I would probably end up with really close to 2:1 ported/sealed and I have a 6" aero I'd be bringing up through the rear deck.
Share this post
Link to post
Share on other sites
can work nicely if you do it right good sir ;) design it properly your good to go!
edit: driver has a decent QTS value so the box shouldnt be TOOO big
specs to help you out
Electrical Q Value (Qes): 0.46
Mechanical Q Value (Qms): 4.4
Total Speaker Q Value (Qts): 0.42
Free Air Resonance (Fs): 26.6 Hz
Equivalent Compliance (Vas): 31 liters
One-Way, Linear Excursion (Xmax): 18 mm
Efficiency (SPL 1W/1m): 83.2 dB SPL
Effective Piston Area (Sd): 310 cm2
DC Resistance (Re): 2.8 ohm
Nominal Impedance (Znom): Dual 4 ohm
Thermal Power Handling (Pe): 600 W
Force Factor (Bl): 17.7
Share this post
Link to post
I've never designed a bandpass but my buddy has done a ton and has quite a few trophies ans titles under his belt but he always does walls and suv's. I was thinking like .6~ sealed each and like 2-2.5 ported.
Edited by k_schutte
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    No registered users viewing this page.
