Fiberglass Amp Rack 101: Build a Custom Fiberglass Mold for Amplifiers, Every Step
mklett33
MI
What’s up ladies and gentlemen of the car audio world? Today I bring to you the all inclusive Fiberglass Amp Rack 101 Lesson! Allow me to insert my shameless plug and say that if you enjoy any part of this tutorial, or learned something new, please post a comment, rank this thread, and share with your friends! Also I love when I get new subscribers on my YouTube channel! (The SECRETS of Car Audio Fabrication! - YouTube ) Other than that let’s review what you will learn shall we?
When it comes to making the Beauty Panel skeleton you are going to want to utilize techniques like router tricks to make pieces that fit within one another perfectly. You will also want to use techniques that allow you to mesh similar pieces of wood into one another to create separate pieces of the amp rack so that the amp rack is an assembly, rather than one permanently conjoined part. Having an amp rack that is multiple pieces that are joined together by bolts and screws is much more effective than an amp rack that is glued or otherwise permanently joined. You want to have access to the equipment.
The methods and steps to effectively doing this are outlined in the following video:
How to build a wooden skeleton foundation - Amp Rack 101 - Car Audio Fiberglass How To - YouTube
Once you have all your skeleton pieces built for both supporting the equipment and hiding the equipment you are going to want to prepare the skeleton for fiberglass, the professional way.
3) Prepping Skeleton and Templates for Molding
Here is where the rabbeting bit and the router come into play. If there was ever one ‘most important step” within the process I would say this is it. This step is often skipped and leads to tons of more effort in the fiberglass stage. Pay close attention to the steps performed here, and follow them!
How to rabbet a groove for fiberglass treatment - Amp Rack 101 - Car Audio Fiberglass How To - YouTube
Following the steps in the video will allow you to cut a perfect step in your skeleton pieces. This step will lead to a flush fiberglass surface that is easier to sand and fill with body filler.
4) Applying Fabric – The Skin of Your Shape
Here is where your design will really start to become a reality. In this step you are going to stretch material and adhere it to the bounding surfaces of your amp rack. This is where properly preparing your amp rack skeleton will really pay off.
Within the video you will see how I stretch the material properly in a manner that avoids sags and wrinkles, and also how to easily adhere the fabric and trim it perfectly.
How to stretch fabric fleece - Amp Rack 101 - Car Audio Fiberglass How To - YouTube
Upon completing the stretching of your fabric you are ready to move onto adding some fiberglass strength!
5) Glassing and Strength:
Now that you have a super clean and functional fabric surface prepared it’s time to add some strength! After all we want our fiberglass amp rack to last for years in the harsh automotive environment, so let’s get to work making it ready for the abuse!
In this step you are going to learn to apply fiberglass resin to the fiberglass, you are also going to learn how to apply fiberglass chop mat. Though there are different techniques that can be used in this stage, this is the method I use and have never had any issues. Note that if you do in fact have access to the “rear” of the panel it is advantageous to apply the fiberglass mat to the rear. This allows for a smoother surface to sand later on, but in my case I did not have this option.
People who are new to fiberglass are often surprised how simple this step actually is! Watch and enjoy!
How to add fiberglass resin and strength - Amp Rack 101 - Car Audio Fiberglass How To - YouTube
---------- Post added at 02:16 PM ---------- Previous post was at 02:15 PM ----------
6) Smoothing and Prep for Finish:
So your fabric surface is now nice and strong! So that means it is now time to smooth things out and prepare for the finish that you plan to apply to the fiberglass amp rack. This steps video will teach you how to properly smooth the surface using a high quality body filler. It will also show you techniques that can be used to help decrease the sanding time, a HUGE time saver! Two key points here:
Milkshake: If you have a relatively horizontal surface you can use what is called a “milk shake” to get things nice and smooth. This is accomplished by mixing body filler and resin with a 3:1 ratio. 3 Parts body filler to 1 part resin. You then add the proper amount of hardener and MEKP that corresponds to the amount of body filler and resin used. Upon mixing you will note that the body filler will lay down extremely well, and be very level, the downside is that you cannot really do this on vertical surfaces, and the body filler also becomes a little more difficult to sand.
Green Stage Sanding: When sanding body filler you want to be sure you are sanding in the “green stage”. What this means is you want to pay close attention to body filler as it is drying. Every 5-10 minutes take a piece of sand paper and try sanding the body filler. If the body filler still seems like “liquid” then it is NOT ready to be sanded. But if the body filler sands with a “foam-like” consistency, almost as if you are grating cheese, then it is ready to be sanded. You can really sand very effectively in this phase. This is also the key reason to purchase high quality body filler. With Rage Gold you will find the Green stage lasts for 20 mins or more. With Bondo brand… well there doesn’t seem to be a green stage.
How to - Body Filler and Smooth Surfaces - Amp Rack 101 - Car Audio Fiberglass How To - YouTube
Note that in the video I am prepping for a vinyl surface, not paint, so I only sand up to 150 grit. If you were doing paint you would want to sand smoother for the primer application… but that is a different How To.
7) Adding Plexi and Inserts:
Now that you have smoothed out your main surface it is time for a step that can really make your install look amazing, and help tie everything together. In my design you can see the shape that I utilized over the amplifiers. It is a rounded rectangle of sorts. In order to make the entire amp rack look appealing I want to carry that design to each piece. In order to carry it to my amp rack “trim ring” I want to incorporate the rounded rectangle shape. I do this in the form of an “insert”, and what better to accent the insert than a piece of plexi glass that can be back lit, or have a logo applied.
In this step I show you how through using router skills you can make an exact plexi glass shape and integrate it behind an insert. I also show you how you can use foam tape and body filler to make a perfect gap for the materials you will ultimately finish the amp rack trim piece and insert with. Big tips here are to use a high quality body filler (as you will likely be doing small detail sanding) and to make sure you use foam tape with enough thickness for the materials you use to finish the pieces.
How to make Fiberglass Insert Templates - Amp Rack 101 - Car Audio Fiberglass How To - YouTube
8) Wrapping the Amp Rack: Vinyl, Suede, and Carpet:
So it’s finally coming all together! You’re ready to finish the amp rack off! In the first video you will learn how I wrap “basic” panels, which basically does not require the use of a heat gun, but requires you to rabbet the edges of the panel for a clean finish on the rear side. In the second video I will show you how to wrap more complex panels, which requires a more aggressive adhesive as well as the use of a heat gun when using vinyl to properly form the piece and avoid wrinkles.
It is very important that you take your time in this step, do not attempt to secure materials before your adhesive is tacky. If you try adhering the materials to early will pay for it later when the material pulls away from the panel. It is also important when wrapping a complex panel to utilize high quality glue, as I will recommend within the video.
How to Apply Vinyl or Suede - Car Audio - Amp Rack 101 - YouTube
How to wrap an Advanced Panel with Vinyl - Amp Rack 101 - Car Audio Fiberglass How To - YouTube
9) Final Thoughts:
Once all your panels are wrapped you’re obviously ready to piece things back together. It is important to verify things are perfectly secure. The vehicle can be a very dangerous place in the event of an accident, so insure everything is held firmly in place.
If you enjoyed this tutorial please comment below, if you utilize any of the methods in this tutorial please feel free to share pictures within this thread of what you made! I love seeing what my lessons have helped people create! If you have any questions please feel free to post below!
Good luck!
~Mark
Definitely was a fan of the tut, man. Makes me feel more comfortable about tackling this further down the road in a Tahoe build if I can't fit my amps under the seats. Not to mention, the sh*t you don't hear in CA vid was epic (at least for me).
Keep 'em coming, man.
That took some serious time and dedication writing that up. I vote for sticky.//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Thanks man, appreciate it, it was a ton of work
Looks good man, lots of great tips. Its helpful for me as I plan on building a amp rack soon. Though it wont be as complicated as some of the work you do, you have given me lots of good ideas.
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
This is correct. Those insurance /extended warranty people dont want to pay for anything that isnt listed on the contract, of which to most is...
124
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
193
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
146
mklett33
mklett33
MI
mklett33
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
