Sub making weird noise?
  • 1
Jleff8621
I plugged in my sub and it starts making this odd sound. When i started playing music and the sub hits it makes this awful sound. i dont know how to explain it. Its like a static, popping noise. I know its not the gain because even when its turned all the way down you can still hear the noisse. The box is the right size. and alll the connections seem to be alright. This has justt got me completely stummped. It cant be the sub becausee it is brand neww. Its an alpine type r 10d2. And the amp is a mrx-m100. Please help!
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
479
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
4
335
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
481
Jleff8621
Jleff8621
Richmond,Va.
Jleff8621
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
