4th order vs vented wall
  • 5
Trevor28139
i have a 2001 expedition with:
2 DD 3515 CF
1 DD M3A
currently have a vented box subs firing up vent back.
going to do a rebuild this weekend and trying to decide between:
A fourth order with subs firing up into vented chamber with vented chamber firing forward, everything walled off behind the back seat.
A vented enclosure subs firing forward vent firing forward everything walled off.
my thought process is that if i wall off the space behind the back seat it reduces the amount of space to pressurize.
my main focus is daily listening but would like to see a nice number on the meter as well.
I dont think that the dd's are suited for a 4th, but im not too sure..I think you should try a 6th order //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
A 6th would be a fun build, but a 4th will work as well. If you are able to design/build it yourself try em both. The baffles for sealing it off should be the same for both options.
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
814
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
Trevor28139
Trevor28139
Rutherfordton NC
pro-rabbit
Bobbytwonames
    Apr 20, 2024
Bobbytwonames
    Apr 20, 2024
