Components im considering. Thoughts?
calebkhill
A few sets of components im considering. Any thoughts? Which would you choose out of them? Or if each could be rated 1-10 on quality and performance.
EDIT: Also with loudness in consideration. I like alot of volume. And, if any other components you know of in 300-450 price range that could out do these listed.
PHD -FB 6.1 Kit Pro
PHD - Speakers - Model FB 6.1 KIT PRO FIRENZE -
CDT CL 62
cdtstore.com/cl_series/cl62.htm
Focal Access 165 A3
Focal Access 165 A3 6.5-Inch 3-Way Component Speaker Kit:Amazon:Car Electronics
Hertz HSK 165 6.5"
Hertz HSK 165 6.5" 2-way Hi-Energy Component Speaker System HSK165:Amazon:Car Electronics
CDT's CL line is entry level. I really enjoyed my CL-62Pro set when I first tried CDT Audio, but compared to the other options they're not in the same league. You'd have to put HD-62 in place of CL-62 for a fair comparison, in which case each set will sound a bit different if you could audition them in the same vehicle. They'd all make a fine choice for a sound quality system. CDT has an extended warranty program to cover manufacturing defects for 10 years.
HSK isn't the lowest of Hertz' offerings, that'd be the ESK, but yeah. Wouldn't go Hertz unless you can afford the Mille
I second the statement on CDT. If you're going with CDT, go HD, not ES.
For Focal, don't bother unless you can step up to the IS, PS, or K2 series
That pretty much leaves PHD and it sounds like those'll be smooth offerings. Just keep in mind there's cost involved.
You could always go with the MS comps //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Don't go es wtf ?? That's the good stuff lmao
Are you going passive or active? If active, do not rule out piecing a 2-way set together. So many more options, and a budget of $400 can get you some good drivers. It's what I'm doing right now.
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
In the $600 range I like my stereo integrity speakers so far Tm65 midbass $399 m25 tweeters $199
What are some of the louder, while still sounding good, 6.5" sets out there? Been looking at some of these higher powered Sky High Car Audio sets...
Hell... Run It!! If it sounds good to you. Then that is what matters the most.. Your OWN EARS.
calebkhill
calebkhill
Phenix City, Alabama
neo_styles
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
