Welding cable 1/0 for BIG3?
Which would be better 100% copper or OFC......?
OFC is 100% copper. Oxygen Free Copper
Welding wire is fine, Audio wire is fine. You wont notice the difference unless its CCA (copper clad aluminum.)
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
simple question
Simple answer
Not sure why it took so many posts to figure this out
Yea but he was lookin at 1/0 welding and it takes 2/0 welding to equal most of these oversized 1/0 audio wire
I'd like to see that comparison, because my 1/0 Trystar OFC welding is just as thick as my 1/0 KNU Kolossus and looks equal to every other 1/0 ive fucked wit stinger/kicker. And I'm not even running 250 amps of current thru it anyway (what my welding cable is rated) so I suppose its a moot point
Only appears that way. Car audio specific wire is usually stranded finer, to get a lil bit more flexibility. Let's say you have the same amount of copper, except stranded differently..., one 1000, one 4000. The 4000 strands will look larger, but weigh the same.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
479
https://www.ebay.com/itm/263364485734?mkcid=1&mkrid=711-53200-19255-0&siteid=0&customid=link&campid=5335951755&toolid=20001&mkevt=1
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Oem cables are readily available for most vehicles. Check rockauto. Anything less will be a future headache.
10
Agoonygoblin
Agoonygoblin
Columbia, SC
bgowdy
Bobbytwonames
    Apr 20, 2024
Bobbytwonames
    Apr 20, 2024
