Jump to content
Sign in to follow this
ausman
Amp install questions
Recommended Posts
I have a 250 rms watt Rockford Fosgate amp and a 1000 rms watt Rockford Fosgate amp that I'm putting in my 2001 v6 mustang, I am wondering what i need to do as far as what gauge of power and ground wire to run and do i need a HO alternator or a better battery to run this system properly?
Thanks
Share this post
Link to post
Share on other sites
You'll want a good battery. Deka Intimidator. Oversized from stock size if you can fit it. The bigger the better. Group 31 if you can.
You may or may not need a new alternator. If you want to really push those amps to the limit, you probably will. A good - and bigger - battery may or may not be enough. You can do a second battery if you want, keeping the stock one under the hood and a bigger one in the back.
If you do a second battery/battery location, you want to use a minimum of 0 AWG wire. If you don't, 4 gauge will work. If you want to be able to upgrade amps to even more power later and/or a battery in the back later, use the 0 gauge now. Personally I say big battery under the hood and alt if necessary.
I know you won't have much space back there but I'm not ever sure I've really checked a New Edge out up close all that much.
2009 Pontiac G8 GT - Selling/Trading soon...
Ebay: ddfromma | Heatware feedback: ddfromma
Share this post
Link to post
what dragonrage says stay with 0 ga. and just get 0/4 ga distribution block to run 4 ga. from there to the amps and also the big 3 under the hood too
Feedback:http://www.caraudio.com/forums/itrader.php?u=1020411
Share this post
Link to post
Ok so i already have 4 gauge ran, so 4 gauge will work without big performance loss if i dont plan on upgrading later.
Share this post
Link to post
the 4 gauge will work yes. but 1/0 is better for the long term in case you plan on upgrading
TEAM AUDIO TECHNIX
TEAM SSC
TEAM CADENCE
Sold to: imtjnotu; ace_800; omegabunny crazykenkid Bought from: El_weenie; fasfocus00; retroaudioinc; f1mclarenagr; jason19; tone415; twizted859; noph33rracing; tony30cl; carlosg_313 Traded with: Micah_Jones; MikeOfTulsa
Apparently I was called out, or called a goat fucker, or something. I really have no idea. Im just along for the ride at this point.
King James has nothing on King Sac!
Share this post
Link to post
So what gauge of wire should I use when going from the amp to my 2 subs
Share this post
Link to post
You can get 10 gauge speaker wire really cheap in the close outs on KnuKonceptz. That would be more than enough size for your set up.
141.8 DB @ 36Hz
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
