Ford H.O. alternator
k_schutte
Item(s) for Sale: American Armature (no American Powr Systems) 240A alternator
Item(s) Description/Condition: Don't know a lot about it. I got it from work (we build police cruisers and other government vehicles), it came off of a crown vic and I ran it on my '95 Explorer. I called them with the part number and they said it was a 240A alt. and should do like 110A at idle with a stock pulley. I had it gone over by Beusings Iowa Generator and they put a new Heavy Duty regulator on it as well as a smaller pulley and new brushes. Has about 500~ miles on it since then.
I was running 3kw~ rms, Optima yellow top (had laying around) and a single run of 2/0 and it got the job done juuuuust fine
Price: $250 shipped to the 48
Wish this fit... Glws bro
Suppoed to be for the 4.6l V8.. hit me up, your pms are full. Im interested if it is definately the same but I cant tell
looks to be the same mounting as the one on my ranger... which was for a 4.0 v6...
Well he said it was from a crown vic and on an explorer so those are 4.6, my grand marquis has a 4.6 V8 and the alt is strong but if this one is legit that would be legit.
The top mounting bolts look right and so does the harness plug
I was told it came off a vic, could be wrong. I had it on my explorer... either way, if someone can't tell by the pics if it would work on their vehicle, I would rather not do business with them anyways. No offense but if that pic isnt enough, probably shouldn't be touching your own **** in the first place.
338
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
k_schutte
k_schutte
cedar rapids, IA
gumby688
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
