Sound Deadening HELP!! MLV and CCF?
rmeekerwrx
I have searched around now for quite some time and can't really find anyone directly addressing my question so here it goes.
I am in the process of adding dynamat to my WRX (focusing on the doors, trunk and rear deck for now) I have already purchased the MLV(Mass loading vinyl) I will be using, and was just wondering is it worth the money and time to add a layer of CCF (was thinking ensolite) first, then installing the MLV over that?
OR would the difference in deadening quality be so minimal that just using the dynmat and MLV would suffice?
Any and all opinions and advice would be greatly appreciated!!
Oh one last question! My MLV is not peel and stick, what are some recommended types of adhesive?
Who/where did you buy the MLV from? MLV requires an isolating layer to work as a noise barrier. If there isn't a layer to decouple the MLV from the panel it will transmit the noise by way of vibrations. The installation method provided by Sounddeadenershowdown.com is brilliantly simple and it allows for the product to be removed and reattached at will.
Thanks for bringing up the SDS tutorial, I was going to hunt for that. OP, you need a three-prong approach, so you want the CLD tile mated directly to the metal surface, the Ensolite over that, and then the MLV overlapping on top of the Ensolite. I've seen where people just use velcro to hold on the MLV tiles since they don't need to be perfectly mated to the surface you're attaching it to.
I’m very far from a car audio expert; one only has to see my recent posts around here to know that. I am, however, pretty knowledgeable on cars...
22
I disagree with most. That **** is very sticky and only needs a quick wipe with isopropyl, assuming you aren't trying to adhere it to carpet or a...
33
1) That is correct. I bought mine from Amazon. Those were the actual links I used to purchase it. If you're budget conscious I'm sure you could...
Very Nice!! I wished Id seen this two months ago. I ended up picking up a BNIB Sony XEC-1000. GLWS!! Ill chew on it a bit,and may pick it up??
rmeekerwrx
rmeekerwrx
Columbus, OH
neo_styles
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
