FS amps A/D/S 830x 8ch, Helix Dark Blue 4 4ch, Planet Audio P1250D monoblock
dragonrage
(Note: Selling subs too! http://www.caraudio.com/forums/subwoofer-classifieds/564593-fs-2xcdt-qes1220-12-sq-subs-2xdayton-rss315ho-44-12-subs-fi-q10.html)
-1x A/D/S 830x 8x40w @ 4 ohms usable down to 4x120w @ 4 ohms bridged. Also usable @ 2-ohm in 8ch mode.
-Good cosmetic condition about 6/10 externally, amp works well. Has crossovers. The potentiometers all work but could use to be replaced to make their operation smoother. I was able to use it in my system for a while with no problem using the crossovers. Manual and one DIN to 6 RCA cable (not pictured) will be included. Some of the RCA jacks could use replacement too but they are all functional. Without the potentiometer and RCA wear, I'd give the condition a 8/10 or so.
All necessary connectors included. Let me know if you want me to set up the crossover jumpers (but not the potentiometers) for you (give me a system description if so). This was in my system for a bit, then came out for space reasons but I hung onto it thinking I would use it some point as it's truly an awesome amp. A/D/S is my favorite old school amp company. I have to downsize some stuff and I have no room for this. I'm downsizing my car, so I have even less room for it. Dimensions are about 10.5" x 15" x 6 1/2".
Has crossovers good enough to use as an active setup. Some of the setup is done with jumpers. The config is silkscreened on the bottom and the manual will be included as well. Again, if you tell me your setup I can do this part for you. Own a rare piece of car audio history!
-$210 shipped ConUS (contact if elsewhere)
Item will be double boxed and well-padded. Carrier will be Fedex or USPS Priority Mail. Items will be insured, but for liability reasons I will require a signature unless asked otherwise I guess. Original packaging not included.
http://www.sosdan.com/sellingstuff/dec2012/ads1.jpg
http://www.sosdan.com/sellingstuff/dec2012/ads2.jpg
http://www.sosdan.com/sellingstuff/dec2012/ads3.jpg
http://www.sosdan.com/sellingstuff/dec2012/ads4.jpg
-1x Helix Dark Blue 4
-Very good condition all around 9/10. Switches and connectors are all in excellent shape and the potentiometers work very well. This was just removed from the car I am prepping to trade in soon and I'd rather just have some extra money to put towards that. Has crossovers good enough to use as an active setup. This amp previously belonged to oldschoolboomer.
4x60w RMS @ 4 ohms
4x100w RMS @ 2 ohms
2x180W RMS @ 4 ohms bridged
Spec sheet @ http://www.products2006.audiotec-fischer.com/englisch/pdf/db2.pdf
$115 shipped ConUS (contact if elsewhere)
Item will be double boxed and well-padded. Carrier will be Fedex or USPS Priority Mail. Items will be insured, but for liability reasons I will require a signature. Original packaging probably not included unless I can find it.
http://www.sosdan.com/sellingstuff/dec2012/helix1.jpg
http://www.sosdan.com/sellingstuff/dec2012/helix2.jpg
http://www.sosdan.com/sellingstuff/dec2012/helix3.jpg
-1x Planet Audio P1250d 1250w Class D subwoofer monoblock amplifier
-This one looks used, 4/10 or so, but it just keeps on pounding. I bought this around 10 years ago refurbished from Planet Audio. It was made in the USA and is quite heavy. It has high and low crossovers. The fan seems a bit loud sometimes, may need looking at. I'm using it at 4 ohms though I have used it at 1 ohm in the past and it has been good at both. It was just removed from service along with the Helix amp as I am selling my G8. This amp has been very good to me.
Edit: I do have the level control, but I don't have the cable for it. What I have will be included. I believe the cable required is of RJ12 or RJ45 type (6 pins used, but I think an RJ45 will fit with 2 unused).
1x500w RMS @ 4 ohms @ 0.50% THD (THD @ rated power - good for a subwoofer amp)
1x800w Max @ 2 ohms
1x1250w Max @ 1 ohm (don't let the "max" fool you - it pounds at 1 ohm)
Spec sheet @ http://www.sosdan.com/P850D.pdf
$95 shipped ConUS (contact if elsewhere)
Item will be double boxed and well-padded. Carrier will be Fedex or USPS Priority Mail. Items will be insured, but for liability reasons I will require a signature. Original packaging not included.
http://www.sosdan.com/sellingstuff/dec2012/p1250d-1.jpg
http://www.sosdan.com/sellingstuff/dec2012/p1250d-2.jpg
http://www.sosdan.com/sellingstuff/dec2012/p1250d-3.jpg
Thanks,
Dan
P.S. will probably be listing some subwoofers, tweeters, woofers, a home theater amp, and more soon. Downsizing a lot of stuff!
P.P.S. Offers accepted for those interested in buying more than one item.
^NOTE: Planet Audio P1250D is sold. I no longer can edit the OP so I am putting this note as close as possible.
-1x Eclipse (by Fujitsu Ten) 3620 (2x60wRMS @ 2 ohms, 2x40WRMS @ 4 ohms, 1x120WRMS @ 4 ohms bridged) stereo amplifier
-This one looks used like the Planet Audio about 5/10. I've cleaned it up and it looks a bit better than the pictures show but could use a bit more cleaning between the heatsink fins. Works well. Reasonably small (at least compared to my other amps). I've used it for stereo speakers and I've used it bridged to a sub, which it actually does a decent job for if your requirements are reasonable. Good amp from a good brand. Been sitting on my shelf for a while but it deserves a good home.
Unfortunately I don't have a spec sheet for it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
$60 shipped ConUS (contact if elsewhere)
http://www.sosdan.com/sellingstuff/dec2012/eclipse3620-1.jpg
http://www.sosdan.com/sellingstuff/dec2012/eclipse3620-2.jpg (Note: The text is easy to read in real life - messed up a little with the flash when I took this)
http://www.sosdan.com/sellingstuff/dec2012/eclipse3620-3.jpg
http://www.sosdan.com/sellingstuff/dec2012/eclipse3620-4.jpg
Man I love that series of Planet Audio amps. I used to have the bigger brother of this amp and sold it for dirt cheap and have been kicking myself for it ever since. Great amp as far as I am concerned. If I had the extra coin I would buy it just because. Good luck with your sale man. Good price on the 4 channel too.
Bump & Added Eclipse 3620 in first reply because I can no longer edit the OP.
Also note that I am starting to put some of this stuff on Ebay today. The stuff is still available for sale here unless it's already sold elsewhere. I will do my best to keep the thread up to date. My Ebay prices might be different but I will still honor any lower prices in this thread for those who buy via the forum (i.e. without Ebay taking 9% of the money for themselves).
Thanks,
Dan
Planet Audio P1250D is sold. Would update the OP to reflect such if I could.
Yay, mine! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Bump. Helix amp is sold. Still have the a/d/s 830x and Eclipse 3620. Subs in link @ top still available, and will be listing some 6-7" woofers and some tweeters in the next few days (will be in a different thread).
a/d/s amp now $200 shipped
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
239
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
817
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
938
dragonrage
dragonrage
Massachusetts
Musicaldelic
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
