Has anyone built an enclosure for an Infiniti G37?
  • 4
NJTStang11
Chicago, IL
So I'm picking up a G37 Coupe in the spring and I'm having trouble arranging the stereo setup.
Everything I've found on the g37 boards (myg37, 6mt, etc) has people purchasing the prefab custom g37 boxes from ebay. They are the 4080 (a sealed 12 in the corner of trunk with 1 cube) or ZEnclosure (a sealed dual 10" in the back of trunk with 1 cube). I found almost nobody that built a neat fitting custom enclosure for the vehicle. Ideally I'd like to do a single 12" ported, but the trunk seems to be brutally small so I'm not sure how do-able this is. I was looking at something like an Fi Q. Sorry for the rant, just wanted to see if anyone has done anything different.
It's not gonna feasibly be done unless you are able to assemble some of the box inside the trunk. Meaning you will have to disassemble it, to remove it from the trunk as well.
find attached pics of my amps and the speakers/sub in my trunk
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
I use these and they work great. I splice them right before the LOC. One leg on the negative the other on the positive.
NJTStang11
NJTStang11
Chicago, IL
pro-rabbit
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
