Questions on amp settings.
  • 3
hutt132
US
I have a Hifonics ZRX500.2 amp and plan to power a Rockford Fosgate PRIME R1S412 sub bridged.
What should I set the mode to: Mono or Stereo?
For tuning the amp, should I start off with the level at .2V?
What would you recommend I put the LPF at?
Edit: Sorry, just realized I am in the Subwoofer section.
Mono
Read up on how to set your amplifier gain (level), for now dont turn it up more than 1/3.
X-over set to LPF
LPF-- around 80hz
MonoRead up on how to set your amplifier gain (level), for now dont turn it up more than 1/3.
X-over set to LPF
LPF-- around 80hz
I watched some videos on how to set the gain. Is .2V the lowest? It has me confused because it's on the right.
Yes, .2v is the lowest, becareful not to over power the sub it's rated for 150 watts rms, while the amp when bridge is rated at 500 watts rms.
Thanks man! I'll be careful.
Holy crap, no. .2V is on the right for a reason, that is the highest gain setting. Your gain is there to match your HU's pre-out voltage. The higher your HU's voltage, the less you have to turn up your amp.
Hmmm, thought it was opposite on this amp, op, try it and find out which direction it increases on very low hu volume.
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
two d2 subs can be wired to .5 or 2 or 8 ohms not 1 heres how to wire subs...
From what I've read, LiFePO4 works with lead acid, LTO does not. I have only personally tried LiFePO4. I personally can't justify the extra hassle...
974
hi all, thanks for allowing me to join your site. im installing 2 soundstream tx4.560 4 channel amps, but i want to run them as 2 channel...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
278
hutt132
hutt132
US
hutt132
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
