Octo-port
JayDubb757
I'm building an octo-port for @B2WJ4\.7 ;
I'll provide pics of the measurements he wants to confirm before shipping.
Will let this sit overnight, and finish it tomorrow...more epic pics to come.
very seeexxii, did you just glue them together?
Thanks!
glued and brad nailed...the plates are just glued.
---------- Post added at 07:34 PM ---------- Previous post was at 07:33 PM ----------
no the pink stuff on the seams is drawn on from a sharpie fyi
The pink stuff is bondo not glue.
Thanks! glued and brad nailed...the plates are just glued.
yeah lol you can see the can right there i was just being a smart azz
Just checking. Lol. but 360/8 is 45, smart ass.
Looks like entirely too much work for a port. It's cool though.
The outside angles are 45 degrees...when you join two pieces together, those angles are half the outside angle.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
824
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
499
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
650
642
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
JayDubb757
JayDubb757
Hampton, VA
04murdalanche
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
