porting through rear deck
  • 2
frogcase2002
alright so i built a box for my zcon inside my trunk cause it was to big to be able to slide in , its 4.5 cf tuned to around 31 with port and sub facing the trunk,, i was wanting to know if there would be any down falls to closing the slot port and putting in one or 2 big aero ports toward the back of the top of the box and go up through the rear deck where the 6x9 hole is. im thinking about doing this because ALOT of air is getting out of my trunk and not making it up to the cabin,, and where my back seats fold down its not big enough to have sub and port facing forward and really dont want to have to cut the box out of my trunk, and i would really like to be able to change the tuning for competitions and stuff
I dont see a problem doing this. On your next build, maybe think of doing a 4th order , using the same concept
thats what i have been wanting to do but a couple different designers says there is not enough room in my trunk cause of how much space the sub needs , 15" zcon
if there is any designers around me that thinks they can design a good 4th order for my car i would really like that and pay good,,, i have a 2005 mercury sable,,,,, i can probley fit a good 6 or 7 cf in there cause my box now is 4.5 cf without port and sub displacement and there is a pretty good amount of trunk space left
Hello there people! Ive recently purchased a car and it came with a sony xav ax headset. It could be an ax3000 or ax3200. Im wanting to upgrade...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
Good luck. Front facing USB it's rare and it's not hard to reroute a USB from the rear. 300 isn't enough for any quality touch screen with 3 sets...
10
969
Stream? Unlikely https://www.smsl-audio.com/portal/product/detail/id/809.html https://helmaudio.com/products/boltdac You might can stream in...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
11
frogcase2002
frogcase2002
hamilton, ohio
frogcase2002
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
