just have a good output. no ipod bs the strong there signal you put to it the more power itll put out.
^^This^^!!
princ3cmo: No offense intended, but I doubt the preouts from that Denon would put out enough signal voltage. I tried going straight out of several Onkyo's, Pioneer's, Marantz receivers to drive my XLS2000, XTi1000, Samson S1000, Audio Centron RMA-800 amps and it never worked well. You'll probably have to pre-amp/line-drive the signal cuz you'll only be getting about half of the amp's output otherwise with no headroom at all.
A great, inexpensive option is to use a DJ type mixer with clean gains. This $250-ish Numark is $99 at GC and will be $79 Black Friday. iPod dock, lots of inputs, digital effects, cross-fade mixing, and yeah, tons of clean gain.
Numark iM9 4-Channel DJ Mixer for iPod | GuitarCenter
I've been using one as a hub for about 6 months to feed the Crowns and Samson. The XLS2000 is powering 3 JL 18W6's runnin IB and shaking the phuk out of the house...with NO BOX!!!
Because of Crown's excellent onboard programming options, you won't need an upstream crossover, time-alignment, etc.
GL Bro!
