woofersetc deal on CDT's & Amp?.. Any good?
Not a bad price at all. The cdt components are a couple of years older stock and don't have a cdt warranty I suspect the amp too but still a decent budget set up Might be ok
you can purchase CDT audio at a great discount from techronics.com, their prices are crazy low.
Techronics is not a CDT Audio dealer. Read the fine print. When they had CDT Audio product on eBay I believe they all said there is no factory warranty. It's no better than buying old stock from woofersetc.
There's a sweet arc 400.4 in the classifieds that is active capable. Buy that and a set of used comps... You will be stunned if you install it right. I have a set of cdts that are nearly identical to the ones in your link and a 120x4 active-capable highs amp (the gear in my sig) that was found for 130$. Total. And it sounds unreal for what I paid.
(NEW) Pioneer 9" DMH-T450EX Digital Multimedia Receiver with Weblink - $189.99 - Free shipping for Prime members...
The one you linked is still a bit iffy if you intend to push things. Consider the cells are rated 100A Max discharge which means if they're the...
5
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
5
Ok wewll shoot...last question. I have the LC2i hooked up to it too. Should I turn those boosts down too?
11
Inocense
Inocense
Chicago, IL
av83
Doxquzme
    Apr 13, 2024
1aespinoza
    Apr 13, 2024
Latest topics
