should i go ported or sealed?
what are you talking about??? It makes perfect sense... Ported enclosures typically require alot more room and produce much more SPL when you're on a budget so, if you have the space go ported, if not, go sealed.. the sealed specs im sure will be atleast .75 cubs smaller then the ported box but you wont get as much spl.... wash rinse repeat....
more or less... yes....... if you have alot of space to meet requirments for 2 ported enclosures for a 15in driver ported will give more... sealed will use less space but sound much better ie SQ.. not as "loud" as ported but will have better sq.. there's gives and takes in enclosures.....
i know that, im not a retard im asking if these individual drivers can work effectively in a ported enclosure that small. They require a bit more space but im asking if they will still work in something that small, get it?
7 cubes should be fine for those in a ported enclosure.
And no, you don't have to go to sealed just because the 1200.1 doesnt have a subsonic filter, you can get an FMOD to block out the low frequencies.
Not AGAIN!
Another sealed vs. vented blanket statement. Sealed will Somehow AUTOMATICALLY sound better than a vented.
What if the sealed box is too big, and the vented box is optimum?
What happens to the low-end output if the sealed is too small, and the vented is optimum AND tuned low?
Common answers? Yes. Sealed will NOT sound better than the vented.
Now...If both sealed and vented were optimum, and the vented was tuned low (24-28hz), I don't know. Different ballgame.
I'm not tryin ta b!tch or anything, I just hate blanket statements like that.
Holla.
if you ain't tryin' to ***** why open your mouth??
Bcuz your statement was misleading.
And depending on how much knowledge the guy you gave "advice" to has, he could be misled, thinking that sealed will always sound better with his driver. Which is NOT ALWAYS the case. Therefore sealed does not automatically "sound much better"... in your words.
I'm not a moderator, and I'm not trying to be a KNOW-it-ALL, bcuz I don't know it all. But I do know that was a false blanket statement.
Your not 100% wrong, your just not 100% right.
Peace out.
I dont care how it will sound i just want it loud! I want o make sure these drivers will be louder ported than sealed even with such a small ported box.
The CT's are nice, That Sundown is a a frik'n beast!
7
525
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
479
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
566
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
890
Burnboy
Burnboy
Kentucky
Burnboy
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
