2 Subs 1 chamber or 2?
from what i've read, it's better to put them in separate chambers. that way, they won't cancel each other out. also, i don't think an amp can put out the same exact power to both subs so being in different chambers should work better. another reason is that if one sub blows, i think that the other would have a better chance of blowing if they're in one chamber. idk, i'd wait for others to chime in but that's my .02
It kind of depends if you are supplying a mono signal to the sub amplifier. If you are supplying a summed signal, than it would be ok to have them in one compartment. If supplying them a left/right signal, where each sub would be running off a separate signal then you will want to have separate enclosures.
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
639
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
281
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
4
375
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
643
Look at the Alpine Type S subs.
19
Demon73
Demon73
Sacramento,CA
ThatChevyGuy
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
Latest topics
