DC Audio 9K Amplifier For Sale - $1,450 Shipped!
  • 5
  • Participants list
SkarAudio
Florida
1. Product:
2. Specs:
9.0kw Output power (RMS) 4 ohm 14.4V
9800 Watts @ 1 Ohm 16 volt
11,000 Watts @ 1 Ohm 18 volt
Input Sensitivity
6V~0.2V Low Pass Filter Switchable
( @ 24 dB Slope) Variable Hz 35~250 Subsonic Filter Switchable
( @ 24dB slope ) Variable Hz 10~50 Bass Boost Variable dB 0-9dB Frequency Response
Hz 15-270 signal to Noise Ratio
dB 100 damping factor
150
% Over 90% THD @ 4ohms
Less than 0.1% Fuse Rating
900 Amps Linked Fuse Rating
1800 Amps Indicator power
Yes Protection
Yes Clip
No speaker & power terminal Mold Type
Yes power Gauge 0Ga x 3 Heatsink Length inch/mm
34.65"/880mm
3. Description/Condition:
Amplifier can be seen in the pictures for cosmetic appearance. It overall is in great condition with just minor signs of normal use. It works perfectly and was tested on our bench. We got this amplifier in on trade from our skar trade in program which is the reason it is for sale. No Bass Knob is included.
4. Price: :
$1,450 Shipped in the lower 48 states. First come first serve - PayPal is sales@skaraudio.com
Again, shipping is free at $1,450. Cash Only. No Trades.
5. Pictures:
^^^^^^ x2
Not B-Stock, this item is used and was traded to us using the Skar Trade in Program. It does work perfectly and is cosmetically in great shape, but we do not rep brands that are not ours, we just sell it for what it is.
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
786
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
113
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
SkarAudio
SkarAudio
Florida
Rolltidetbw
SlugButter
    Mar 28, 2024
SlugButter
    Mar 28, 2024
