Help with measurents to build a Bandpass box for a PowerBass L-124D
  • 1
Changchung
18
Ven
Hi everybody, well, like the tittle say, I have a PowerBass L-124D that I want to use in my car, I have a hatchback, so I think that the best box is a bandpass, or is what I want, I need you expert help to let me know what measurents of the box I need to build my box. I will like the hertz cut around 30hz to 40hz
This is what I have of the sub
Power Handling
(RMS/Peak): 400/800 watts
Nominal Impedance: Dual 4-ohm
Voice Coil Size: 2 in
Frequency Response: 24Hz - 400Hz
Sensitivity: 92dB
Motor Structure: 180 oz
Mounting Depth: 5.4 in
T/S Parameters
VC Impedance: 4 ohm + 4 ohm
Test Impedance: 1.6 ohms
Fs: 29 Hz
SD: 471.4 sqCM
Vas: 59 Ltr
Cms: 207 µM/N
Mms: 141.5 g
BL™: 11
Qms: 5.2
Qes: 0.54
Qts: 0.49
No: 0.218%
Spl: 92 dB
Xmax: 9.5 mm
Thanks a lot for the help...
//content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif//content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
67
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
155
11
350
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
240
Changchung
Changchung
Ven
Changchung
1aespinoza
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
Latest topics
