help: 16v batts and HO alt
  • 1
  • Participants list
tundra1221
first time messing with 16v stuff. first of all if i get a HO alt that charges at 18v will that mess with the rest of my cars electrical? Can i run 12v batts off of a alt that charges at 18v? what are some good cheap 16v batteries? how many AH of 16v batts would i need for a 6k set up? what company of HO alts should i go with? sorry for 20Q's just lookin to learn //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what 2 16v batteries would u recommend? don't plan on running with car off at all.... what is a reliable step down brand/model that u would recommend...thanks for the feedback
would 2 xp1000's on a 300A alt charging at 18v satisfy my electrical needs? amp's:cadence zrs c5 (5100rms @14.4) and c9 (~1000rms @ ?)...... thanks for the feed back
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
120
I have a bunch of amp but the sundown and the skar are two highest wattage ones. what amp would be needed to be enough for that skar 15" i thought...
18
423
That is correct. I like these as they are twisted pair and the RCA ends are thick and grip quite nicely...
320
313
Big 3 will not help dimming. Big 3 helps get more power to your amp, which is the opposite of what you want to reduce dimming. Either add lifepo4...
291
tundra1221
tundra1221
spokane, WA
tundra1221
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
