Kicker Impulse IX405D & IX254 (Old School Goodies)
  • 2
  • Participants list
asianinvasion21
ai217
Kicker Impulse IX405D (5 channel)
Kicker Impulse IX254 (4 Channel)
These are both sound quality amps that are becoming harder and harder to find. This is a great opportunity to go active if you decide to purchase both amps. The 4 channel can be bridged for a more sufficient output on your mids if desired.
Kicker ix254 9/10 cosm 10/10 mech
Kicker ix405d 9/10 cosm 10/10 mech
Specs for ix254
2-, 3-, or 4-channel output
Tri-Way capable
frequency response 20-20,000 Hz
25 watts RMS x 4 at 4 ohms
65 watts RMS x 2 in bridged mode
35 watts RMS x 4 at 2 ohms
requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
speaker-level inputs
preamp outputs
MOSFET power supply
two 0-18 dB bass boost circuits centered at 40 Hz
two 0-12 dB treble boost circuits centered at 18,000 Hz
two 18 dB/octave high-pass/low-pass crossovers switchable at 70 or 110 Hz
10-1/4"W x 2-1/2"H x 9-1/2"D
Dynamic Power Rating (measured at 14.4V):
Bridged Into A 4-Ohm Load: 85 watts x 2
Per Channel Into A 2-Ohm Load: 42 watts x 4
Per Channel Into A 4-Ohm Load: 30 watts x 4
Continuous Power Rating (measured at 12.5V):
Bridged Into A 4-Ohm Load: 65 watts x 2
Per Channel Into A 2-Ohm Load: 35 watts x 4
Per Channel Into A 4-Ohm Load: 25 watts x 4
Ix405D specs
3-, 4-, 5-channel output
40 watts x 4 + 200 watts x 1 at 4 ohms
55 watts x 4 + 290 watts x 1 at 2 ohms
115 watts x 2 + 200 watts x 1 in bridged mode
requires 4-gauge power and ground leads — wiring and hardware not included with amplifier
MOSFET power supply
0-18 dB bass boost circuit (centered at 40 Hz) on subwoofer channel
two 0-12 dB treble boost circuits (centered at 18,000 Hz) on front and rear channels
two 18 dB/octave high-pass crossovers (switchable at 70 or 110 Hz) on front and rear channels
low-pass 18 dB/octave crossover (switchable at 70 or 110 Hz) on sub channel
20-3/16"W x 2-1/2"H x 9-1/2"D
dash-mountable gain controller
Four Channel Section:
Bridged Into A 4-Ohm Load: 150 watts x 2
Per Channel Into A 2-Ohm Load: 75 watts x 4
Per Channel Into A 4-Ohm Load: 55 watts x 4
Bridged Into A 4-Ohm Load: 115 watts x 2
Per Channel Into A 2-Ohm Load: 55 watts x 4
Per Channel Into A 4-Ohm Load: 40 watts x 4
Subwoofer Section:
Into A 4-Ohm Load: 275 watts x 1
Into A 2-Ohm Load: 390 watts x 1
Into A 4-Ohm Load: 200 watts x 1
Into A 2-Ohm Load: 290 watts x 1
I believe both amps are underrated and the class d section on the five channel is definitely underrated.
Kicker IX 254 $75
Kicker IX 405d $200
($250 for both if purchased together)
You Pay shipping the ix254 should fit in a flat rate box and the IX405D should cost a little more on shipping.
if a guy wanted to get both of these and go active, i have an extra sink-link. i bought 2 of them, and only need1. yes, they are real underrated. that big amp in my avatar is an ix2302. 960rms@12.5, iirc
726
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
asianinvasion21
ai217
asianinvasion21
Huntington beach, ca
asianinvasion21
    Mar 28, 2024
    Mar 28, 2024
