Question about subs under the seat? In a extended cab. 08 gmc Sierra
Jesus805
Sb
So I am going to start building my system for my 08 gmc Sierra extended cab
So for my subs my local car stereo guy told me to our some powerbass xl 10" subs.. He says those are a good bang for your buck.. I was maybe thinking some hdc3 10 or sundown sa 10
They will be powered by an alpine pdx 1.1000 under
And they will be going in a custom box under seat
Or what other subs do u guys think?
For overall performance a down firing enclosure is very nice and using up the area under the seat can work out very very well if done correctly. However, you have a limited height unless you raise the seat up and that will create issues with what you can use.
However, you are not limited to down firing in those trucks. You can do sub forward port forward, or sub forward port to the side, or a few other options.
While a center console enclosure works very well, I don't feel it is the correct answer for most installs. It just works and many times is quicker/easier then other options. Not to say it is a bad choice, it is just not my first choice.
Yeah.thats what I was thinking
Originally I wanted to put my type x under the set but too much of a head ache
With only 1k rms I would shy away from hdc's as you will barely get them moving. I'm a big fan of 8's so I would do a 4th order for 2 SA's .8 sealed 2 ported around 48. Should get loud and have a great bandwidth while using the power you have quite well.
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
578
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
370
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Jesus805
Jesus805
Sb
Jesus805
    Apr 17, 2024
HandsomeSteve
    Apr 16, 2024
