Which Sub? HDC315 vs. SA NS v.2 vs. DD3515
skrilla22
Been about 4 years since I had a system, and I'm desperately wanting a decent setup again.
My previous setup was a 15" Fi BL fully loaded on a sundown 1500 @ 2ohm. I enjoyed it, but this time I'm looking for a bit more..Been doing some research but with all the new brands and companies, I need some help. Depending on the sub I get, I will either go with a sundown 1500 or AQ1200/2200.
Been looking at an AQ HDC315, sundown NS, or maybe a DD3515. Looking to spend about $700 for Amp & Sub.
Let me know which I should go with, or if you have any other suggestions for a sub that handles about 1200-2000rms.Will go in a ported enclosure to subs specs, in an 02' Explorer.
Thanks
Nightshade destroys the other 2 easily.. Nightshades are a little harder to find now, unless going used. The zv3 would probably be an even better choice with the power you have. That would still be a much better option than the others..
You can get Skar Audio B-stock for under $200.....
//content.invisioncic.com/y282845/emoticons/escape.gif.52b661afb17bde1db0e0c7da97e75b38.gif//content.invisioncic.com/y282845/emoticons/hide.gif.2d479cfd917eedfe201353b91522ceab.gif
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
480
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
337
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
482
skrilla22
skrilla22
Tacoma, Washington
mlstrass
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
