I need mounting specs on the CDT components.
  • 2
gibhunter
I'm considering both the CL-61A as well as the HD-62EF. My cutout for the tweeter is about 2" (could be just under 2") and I'm not quite sure if it's too big for the 3/4" tweeters included in the CL-61A set.
My mounting depth limit is 2" so I'm quite positive I'll need a spacer ring, though I'm not quite sure how big a spacer ring I will need. Is 1" enough? I think it's enough for the CL series. How about HD series?
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
328
347
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
gibhunter
gibhunter
Southington, CT
sumone
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
