SK-1500.1 jumps into protect at high volume
JoeK
Ringtown, PA
It just started doing this yesterday. When i play music at higher volumes the amp will jump into protect in about 3-4 seconds in doing so. Low volumes work great, its just when i go into high volume. The subwoofer is fine and not blown or damaged.
I contacted Kevin about repairing it out of warranty, but ill weight that against the cost of an AQ2200D used, or maybe even a Crescendo BC2000 new
hey joe, you check all your power and ground connections with a DMM? Go over each onefrom the battery back with a DMM and especially across the fuse holder, you might have a loose connection causing voltage losses.
That's where I would start too!
Before sending it in - I would do make sure all of your corrections are solid as they said - might save you having to wait on shipping, etc when the amplifier is perfectly fine.
Connections were tight, and voltage was perfect at the amplifier tested with a DMM. It would go off at my full 14.4V.
I opened the amp before i packed it up to check it visually and i didnt see anything wrong with it at all.
The sub looks fine, the amp looked fine and the electrical looked fine. Even had new batteries... The amplifier is throwing the red light so thats what i have to blame for now. It was only $28 to ship to Amp medics.
discrepencies?
Hmm? It seems odd how it all happened. I put my gains up to clamped 1500watts power, it lasted maybe 2-3 hours of playtime before it kicked off. Once it kicked off, it did it ever since at any high volume regardless of gain setting
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
193
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
441
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
736
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
720
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
917
JoeK
JoeK
Ringtown, PA
cdc351jeferson
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
