FS: Sony Mobile ES 7547 AKA "Big Red"
  • 4
mpowered325is
Seatte
For sale in great condition is a Sony Mobile ES 7547. BIG power 4ch as some of you know. Its a big case amp so you better have some room. But its worth it for the great sound quality these old Sony's produce.
This amp can do 250x4 @ 2 ohms continuously, not peak.
Also can use any ohm sub on the rear channels as it is switchable for 4 or 2 ohm and 1 or .5 ohm
100 AMP Fuse
Exterior 9.5/10
Function 10/10
$250 shipped OBO
Shipping included in price from 98057
I'm only commenting because you asked me to...
The amplifier is rated at 75W x 4 at 4 ohms and 0.04%THD. The amplifier is 0.5 ohm stable, but only for channels C/D. It accomplishes this by paralleling the output devices via relays. So rather than being "bridged", the channels are paralleled in mono mode.
The outputs are interesting devices. They're MosFets rated at 100V and 70A; a great combination. The rails are +/- 28V in "high voltage" mode. This gives you ~150W into 4 ohms.
You can see where this is going.
At 2 ohms and in "high voltage" mode, you're still at 28V rails so ~250W per channel (that's 250W x 4) is not unrealistic when playing music (as opposed to test tones).
At 0.5 or 1 ohm, the amplifier should be switched into high current mode, because you will almost certainly reach an overcurrent situation quickly at 28V rails. When switched into high current mode, the amplifier halves its rails to 14V so as not to trigger an overcurrent situation. So you're limited to the same amount of power.
So what's the point of having the 0.5 and 1 ohm capability if you don't gain anything? It's partly marketing. People see that and think "superior amplifier" when it's more "bait and switch" and "LOL..." to us engineers. You aren't gaining anything but flexibility, which is valuable in its own right - but don't go changing your woofers just because it can drive 'em.
The other part is stability. The output transistors can't drive sub 1 ohm loads without blowing up, so Sony implements some extensive overcurrent circuitry to force you to switch into another, lower voltage mode.
"High current" sounds better than "low voltage", but it's the same thing in power supply engineering-land.
Another thing - there is a sh*tload of SMD circuitry under that "sparse" board. It always kills me when some chucklehead opens a Japanese amplifier on AmpGuts.com and comments on the low parts count.
It's a solid amp. If it wasn't so huge, I'd have no problem owning one. I bet it sounds divine.
557
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
894
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
mpowered325is
mpowered325is
Seatte
mpowered325is
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
