need some guidance / help
Wire both subs together down to .5 ohm into the amp. The amp accepts inputs for each sub individually but internally runs them together to make it a single channel.
245
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
266
521
slammincharger
slammincharger
central texas
slammincharger
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
