Speaker Setup/Advice
  • 1
I have an 09 Jetta that has a lackluster factory speaker setup. I have updated my HU and that helped considerably. Still yet, the sound is basically garbage. I'm wanting to run a whole new set up and would like a little advice on where to go with it. Mostly likely looking at putting in 6.5 component systems in all doors and running that off of an Alpine 4 channel amp. I'm getting a high wattage amp because I know that setup will be power hungry. The front doors have 3 speakers from the factory that include an additional 4 inch speaker. I'm considering a couple options with this extra spot.
1. First option is to simply not use it. I know when it comes to sound fields, more doesn't necessarily mean better.
2. I don't really want to run a 3 way crossover, seems pointless and not worth the money. With all 4 channels on the amp already used, that would be the only real option if I wanted to stick a speaker in that spot and run it amped.
3. Put in a 3.5 inch 2 way speaker and simply run it off the HU. I'm not sure that this would even put a dent in what I hear or have any positive effect whatsoever. It very well could just end up being a waste of money.
So all you pros, I would appreciate some shared expertise and a point in the right direction. Thanks in advance!
ok thanks guys for y’all’s input that really help a lot
Personal opinion Spend the money you were going to spend on the rears on the front. Placing the tweeter on the dash can work well. Cdt might have...
Yeah they do still make good hardware after all this time...
Hmm. Maybe so. Ive never been more alert driving/riding than being on a Cycle man. Several think you just get on and ride away. A good set of...
26
5K
True but at those prices, nickel plated copper or brass would be a much better option for speakers, no point in using stainless steel at all...
24
302
justuntlsundown
justuntlsundown
Huntington, WV
justuntlsundown
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
