HDC3 Box and tuning for explorer
sleazebagger
nobody!!!
3,337
Madison, WI
Next week I will be building a box for my explorer with two 18' HDC3's. Running a VLF 400.1 so these will get everything they can handle.
I don't have to much room to work with but it should do. 44.5 W 30 D 23 H. Was thinking of using aero ports and tuning to 39hz.
After searching the interwebz and seeing vids with these subs I wasn't very impressed by most setups. I guess that's what one gets with a pair of semi budget subs.
Anyway I would like some suggestions if you have experience running these in an SUV. From what I hear these need a lot of room and high tuning.
Thanks much
12ft3 is the min but will work pretty good. I wouldn't go much over 23 ft3 for the max. If you are wanting max output go slot port and use a large amount of port area. The tuning is up to and your goals.
YouTube is not something you should base your expectations on. There is no way to tell truelly whatvs system sounds like or anything from s video.
from what I have learned with explorers, they like to be tuned around 48-52Hz. Aero port would be the way to go because you can adjust it to be tuned anyway you want really. I would deff say go with at least 3 1/4 cubes of internal air space per sub though. There is a guy on here named Bill Lolo a.k.a @psychoacoustics ; who makes custom 8" aero ports out of welded steel that slid in and out to make it fully adjustable without cutting or adding anything. http://www.caraudio.com/forums/subwoofers/550511-where-buy-aeroports.html#post8080998
aeroports pictures by psychoacoustics - Photobucket
[quote name='xSPLoder808']from what I have learned with explorers, they like to be tuned around 48-52Hz. Aero port would be the way to go because you can adjust it to be tuned anyway you want really. I would deff say go with at least 3 1/4 cubes of internal air space per sub though. There is a guy on here named Bill Lolo a.k.a @psychoacoustics ; who makes custom 8" aero ports out of welded steel that slid in and out to make it fully adjustable without cutting or adding anything. http://www.caraudio.com/forums/subwoofers/550511-where-buy-aeroports.html#post8080998
aeroports pictures by psychoacoustics - Photobucket[/QUOTE]
Umm lot of fail in that post.
mind you the size of an explorer rear cargo. just built a box for a friends explorer and it's 6cuft including port. There is maybe 3 inches left from side to side after the box was done, port and all. I will tell you one thing though sleez, my explorer loves loading off of the hatch. I've tried port firing off passenger side, driver side and port facing windshield and my highest meter read was off the hatch.
Let's just point out your 3.25 cubes per 18" hdc comment really they are not a small box sub at all.
Dude I know you have a ton of experience with explorers so why don't you just drop some knowledge and stop flaming.
when you say loading do you mean ports about 8 inches from the hatch?
I would say more around 5 to 6 inches from hatch. Mind you, if my previous post was read correctly, I said minimum 3 1/4 cubes of internal airspace per sub
Tonight when I get on a computer and pull all my old data up.
That would be cool cause I'm lovin' that box in your sig:)
---------- Post added at 07:03 AM ---------- Previous post was at 07:02 AM ----------
cool... that gives me 2 more inches then:)
i also would like to see where the "lots of" fail is. you might not of agreed with the size I said, doesn't mean it's wrong though. sleez, i'd put money on your explorers vehicle tuning being within the freq range I mentioned
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
243
I have been attempting to study the true nature of why we tend to tune transmission lines and enclosures in general like we do, the nature of...
Go get some shitty wood or cardboard or something and figure out what the max is, play around with different dimensions to see what the max cubic...
23
774
Opted to show my buckeyes some love. Used some padding and also a unique piece of laminate I hade laying around. Needless to say, I’m happy it’s...
6
428
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
785
sleazebagger
nobody!!!
sleazebagger
Madison, WI
dbeez
MrG
    Apr 18, 2024
MrG
    Apr 18, 2024
Latest topics
