Do I need a fuse on the power wire from the alt to the battery?
you don't have too in fact it works best without a fuse, but at the same time your giving up safety if the wire comes loose from the alt it will short out and damage your battery as well as possibly start a fire/explode. I like to double stack fuses on that lead if in a crash and shorted it will blow but it will take a sec.
yes fuse it for safety... fuse at your wires max amp rating
yep max rating, if you look what that is on 3' of 0g you will see why i double them up! and if you check across the ohm/resistance load of them doubled you will see a nice difference!
ABSOLUTELY fuse it, and a 300 amp fuse is spot on.. 1/0 gauge wire varies brand to brand, but 300A is right., Some people will disagree, and say fuses aren't necessary, but they are WRONG. ESPECIALLY between your alt. and battery. It WILL NOT have any EFFECT on your systems perfomance.. BUT, IT WILL protect your system. Fuse it or lose it. Hope i helped you bro... Bring on the haters.
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
311
339
If you can find these in your area. Id recommend these for drop ins. They play from 40Htz on up. Sound very nice on amplified power for premium...
trenthonda1
trenthonda1
Florida
mlstrass
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
