problems seeing hu in sunlight
Messed with the brightness and tint it didnt really help. The only color that you can see good is green. Its more the glare than any thing.if theres any light at all glare is horrendous. I will check if dimmer is hooked up but i dont think it is.
ive got a kenwood as well but i have 5% tint all around and 35% on the windshield. i never have any sun glare problems //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
629
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
730
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
I feel like its a bad set(Low tier set) of RCAs myself. I use Stinger Zero Noise and 4000-8000 series without any issues. Dayton makes a nice set...
ewadz3006
ewadz3006
erie, PA
Dirtrider4eva
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
