OVERSTOCK SALE: Chevy Cobalt, Cavalier, HHR Ecotec 270 AMP MECHMAN ALTERNATOR
MECHMAN
OVERSTOCK SALE:
Chevy Cobalt, Cavalier, HHR Ecotec 270 AMP ALTERNATOR
Sold with SELF EXCITING REGULATOR ONLY
*Does not accept factory plug / adapter
**Check engine light will show on display
***Eliminates PCM voltage control
Regularly $449 / Now $349
Shipping ranges from $15 to $25 within the lower 48 U.S. States
CALL 888MECHMAN EXT. 202 FOR DETAILS
You don't need to plug it in. Which is good, the PCM on your car limits the voltage = bad. Mine limits it around 13.8-13.9 etc.
the self exciting will turn its self on automatically when the car starts.
The only bad thing is that you will get charging error lights on the dash
You don't need to plug it in. Which is good, the PCM on your car limits the voltage = bad. Mine limits it around 13.8-13.9 etc.the self exciting will turn its self on automatically when the car starts.
So just bolt up and connect big 3 wires and that's it?
Yep that's all you need it has a "self exciting regulator" aka when it starts turning, it turns it on.
Man y can't this be for non-ecotec cavaliers //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Bump
item(s) for sale:
overstock sale:
Chevy cobalt, cavalier, hhr ecotec 270 amp alternator
item(s) description/condition:
sold with self exciting regulator only
*does not accept factory plug / adapter
**check engine light will show on display
***eliminates pcm voltage control
price:
regularly $449 / now $349
shipping and miscellaneous item information:
shipping ranges from $15 to $25 within the lower 48 u.s. States
call 888mechman ext. 202 for details
item pictures:
(list pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-trader system or less than 10 references that you have sold to in the past. (these must be listed in your signature, or a link provided to a feedback thread listing these references)).
i have a PCM controlled HO in my cobalt and I hate it. I was wondering if you get a battery light it will pass inspection or do you have to put the old alt back?
I would check the inspection laws in your state. I do not believe that a charging light would fail as much as emissions or poor brakes.
OVERSTOCK SALE:
still have these in stock? Also what can I do about the light due to inspection?
Very Nice!! I wished Id seen this two months ago. I ended up picking up a BNIB Sony XEC-1000. GLWS!! Ill chew on it a bit,and may pick it up??
i know that don’t change nothing thought i would share just let me know k if u want to text or email about it i will send u my info
955
e heard decent things, I've not used it, but for noobs, good place to start with that new DSP setup...
COMPLETED Full system sale
Changed my mind, the jetta is staying as-is and I'm buying the new car anyway, close this *****! Matt
MECHMAN
MECHMAN
Knoxville, TN
rebelfromva
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
