Jump to content
MECHMAN
OVERSTOCK SALE: Chevy Cobalt, Cavalier, HHR Ecotec 270 AMP MECHMAN ALTERNATOR
Recommended Posts
OVERSTOCK SALE:
Chevy Cobalt, Cavalier, HHR Ecotec 270 AMP ALTERNATOR
Sold with SELF EXCITING REGULATOR ONLY
*Does not accept factory plug / adapter
**Check engine light will show on display
***Eliminates PCM voltage control
Regularly $449 / Now $349
Shipping ranges from $15 to $25 within the lower 48 U.S. States
CALL 888MECHMAN EXT. 202 FOR DETAILS
Builder of alternators.
http://www.mechman.com
865-522-6166
1-800-MECHMAN
Share this post
Link to post
Share on other sites
What fi I need to plug this in?
09 Cobalt LT
Headunit -Alpine CDA-9887
Front Stage - PHD FB 6.1 PRO SIX M/B, FB 5.1 m/b, FB 1.1b tweets
Highs amp -Pheonix Gold Xenon 100.4 & 200.4
Sub stage - 2 DC M2 LVL 5 12s
Sub amp - 2 DC 5.0Ks
Electrical - Singer 270 alt, big 3 0/1 & 12g ofc audio technix, 2 XS d3400s
Deadener - 80 mill Audiotechnix deadener
"Trunk hit hard like Kimbo Slice"
TEAM DC AUDIO
Share this post
Link to post
You don't need to plug it in. Which is good, the PCM on your car limits the voltage = bad. Mine limits it around 13.8-13.9 etc.
the self exciting will turn its self on automatically when the car starts.
The only bad thing is that you will get charging error lights on the dash
Refs:
sefugi x2, S.DeYoung, SteveMead, chillin, rebelfromva, Got160s?, JL Audio , mclerico83, and BIGJEFF64.
Share this post
Link to post
So just bolt up and connect big 3 wires and that's it?
09 Cobalt LT
TEAM DC AUDIO
Share this post
Link to post
Yep that's all you need it has a "self exciting regulator" aka when it starts turning, it turns it on.
Refs:
Share this post
Link to post
Bump
item(s) for sale:
overstock sale:
Chevy cobalt, cavalier, hhr ecotec 270 amp alternator
item(s) description/condition:
sold with self exciting regulator only
*does not accept factory plug / adapter
**check engine light will show on display
***eliminates pcm voltage control
price:
regularly $449 / now $349
shipping and miscellaneous item information:
shipping ranges from $15 to $25 within the lower 48 u.s. States
call 888mechman ext. 202 for details
item pictures:
(list pictures in this section, 1st picture should be your username/date if you have less than 10 positive feedbacks with the i-trader system or less than 10 references that you have sold to in the past. (these must be listed in your signature, or a link provided to a feedback thread listing these references)).
865-522-6166
1-800-MECHMAN
Share this post
Link to post
So i guess a no go for my 03 saturn ion?? Same motor as cavi of its year..
RIP Maynard "My heart"
1996 Ford Explorer 4 door XLT
HU - Eclipse cd-7100 "active"
Front Stage - 2 Alphard mx60 mids- 2 Alphard mx80 mids - 4 Hertz ST25's
Front Stage amp - 2 Alphard 200.4
Subwoofer - Custom
Subwoofer Amp- Soundigital 8.8k
Box - 3.5cf tuned @ 33hz
Wiring/Electrical - 4/0awg weld, JY 79.8Ah lithium, 290&370 hair JS Alternator
Share this post
Link to post
OVERSTOCK SALE:
still have these in stock? Also what can I do about the light due to inspection?
09 Cobalt LT
TEAM DC AUDIO
Share this post
Link to post
Guest
This topic is now closed to further replies.
  • Recently Browsing   0 members
    No registered users viewing this page.
  • Similar Content
    • By subzero
      Stay tuned...
      Two
      X3.71's
      X3 Amplifiers
      Two
      X3-122's
      X3-Subwoofer
      75 feet of 1/0 gauge welding cable
      Two
      BATCAP 2000's
      Two
      300 Amp Alternators from Excessive Amperage
      36 sqft of Stinger deadener
    • By cbrownstudios
      I have a pioneer DXT-2266UB headunit with 2 10" MTX subs on a 500 watt sony xplode amp. Everything was working fine until recently. one day i turned it on and the subs werent hitting. i popped the trunk and it seemed that the subs were playing music but barely any bass and a low volume. when i turn up the volume on my headunit, it doesnt seem as if the speakers are getting enough power.i have pulled everything out and checked the wiring and it all seems to be fine. i have checked the pass filter and thats not it. i checked the power cables and they seem tight, however the ground wire seemed to have coroded a way some, leaving a strange white dust, so any ideas?
      possibly either
      -fuse on powercord
      -or need new ground wire?
    • By zwhite93
      I would like to add an auxiliary input to my 2004 Chevy Cavalier factory radio. It is an AM/FM/CD (single) unit. I know that there are converter boxes out there but here is what I would like to do. Can I make a Y cable out of all of my speaker leads, tie together the +'s and -'s into two leads, and run them to a 3.5mm plug? I am assuming I will need a small amp so that the battery isn't drained on the source (an mp3 player), and will need inline switches to reduce noise when I am not using the AUX input. Can I put one inline switch on the high side of each of the four + leads? I am aware that by tying all of the +'s and -'s together, I will loose all fade and balance, but I keep everything zeroed anyway, so that is no biggie. What would you recommended for a 12V amp? What other issues might I run into? Thoughts? Thanks
    • By rlyster17
      is it possible to get an 8 inch midbass driver (JL Audio ZR800-CW) into the stock speaker location of a chevy cavalier. i currently have 5.25 coaxials in there and i know you can fit 6.5's but i was wondering about 8's. i would go measure myself but the car is in the shop for repairs. I would like to put a set of 6.5 components in the kickpanels and have the 8's in the doors. Is this possible?? if so whats the best way to go about doing it??
