Jump to content
Sign in to follow this
splwj47
help with tweeter noise (running active)
Recommended Posts
so i went active this weekend and ever since i did i get the hum threw my tweeters, it is very annoying and after rewiring everything today to make sure the rcas wernt close to the power wire or the ground wire i still have it. here is a vid of the noise.
here is a pic of everything all wired up. there is only the one spot where the speaker wire is close to the ground and its only for about 6 inches.
2003 JEEP Grand Cherokee
HU- pioneer 80prs
Front Stage- Tantric HD comps.
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
Subs- Tantric HDD 12's
box - 4.5^3 32hz
Share this post
Link to post
Share on other sites
your getting interference from somewhere.maybe the rca's for the tweets
[sIGPIC][/sIGPIC]
pioneer avhx 4800 dvd, ampere tfhe 9.0 and 150.4 with arc audio xxd 4080
4 d3100 and 3 deka 8a31 and d975 ,270 dc power and 320 amp singer alt
B2 ref mids,Cdt es6 mids cdt es 010 tweets x2 ,es 03 Mids x 2 mx1000 , sky high ,eb flex, and stinger hpm o gauge wires ,also 2 crossfire xsv2 18s in a 4th order no wall box
NOR CAL DB DRAG JUDGE
http://www.dcsoundlab.com
Share this post
Link to post
i have no idea where tho the rcas are ran on the right side of the car and the power is ran on the left.
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
maybe from the wires from the car if they are under the rca ,i've had that issue before .also look for a pinched wire somewhere too ,that can cause this
[sIGPIC][/sIGPIC]
Share this post
Link to post
well there is other wiring down the right side of the vehicle, but its just for heated seats/power seats maybe something else to, but i dont know. i know there is no pinched wires i made sure everything was good when i installed the wiring. i never had this noise running passive. but it must be something with that 3rd rca i just installed since it is just threw the tweeters, but it was installed in the same place and the other 2 rcas. so i dont know.
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
may not be a good rca doug
[sIGPIC][/sIGPIC]
Share this post
Link to post
Lol its the brand new one i just got from you.
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
hmmm if you have another one switch it and see if you still have the noise
[sIGPIC][/sIGPIC]
Share this post
Link to post
i dont have another set hmmm.
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
same thing here :( so i just removed the tweeters and went passsive but still have my mids active
HU:Pioneer 80-PRS
Fnt&Rear Spkrs: 8 Neo-Pro-v.2 soon
Mid Amp: Sax-50.4& Sax-200.4
Subs: 4 Sundown Audio 18s Z v.4 tuned at 15hrtz
Amp: 2*NS-1s
batts:,xs2500,xs3000 x20
wire:0g OFC Audio Technix
alt: 3 HO alts from??? from mechman or singer?
Share this post
Link to post
well wtf, at least im not alone lol. if i cant get rid of this whine im just gonna go back passive. which sux.
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
on my mids you can barely hear it but still its annoying. im going to try and swap out HU units and see if its just my head units because i already tried three rca's
HU:Pioneer 80-PRS
Amp: 2*NS-1s
Share this post
Link to post
ya seeing as how we have the same head unit it could maybe be something with it. let me know how that works out when u try swapping it out.
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
ill let you know for sure man. gl with you fixing the problem.
HU:Pioneer 80-PRS
Amp: 2*NS-1s
Share this post
Link to post
anyone else have any sugestions
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
turn your gain down on the tweeter channel or if your hu has level matching built in turn your tweets down, I had this problem and turned my gains down just a little bit and level matched and it went away
Bought from: Misfit138, Nateberrier, Loudrc, Jarvisb, DMP, RAM_designs, go_go_thrash, alxmlr789,imjnotu
Sold to: Lazyrider, TaylorPro, AJM511, Energizedsbs, diarmer, sobe3yourself
Traded with: Vitveet, Resko1 x2, Suicide Bobb, Dumple
More that I've forgotten now and some more in progress
http://www.caraudio.com/forums/buyer-seller-feedback/506469-umwdawg92s-feedback-thread.html
Share this post
Link to post
tried turning the gain down for the tweets and didnt do anything. it made it a bit quieter but didnt go away, went all the way down with the gain and it was still there. what does this level matching do that u speak of?
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
My alpine 9887 has level matching for running active so that if you tweeters are way more sensitive you can turn them down a few dbs to match your mids but sounds like you may be getting some weird outside interference if it still does it on minimum gain
Share this post
Link to post
my tweets are ran at -3db, mids and subs are at 0bd
HU- pioneer 80prs
FS Amp- B2 Quattro
Sub Amp-B2 Zero1
box - 4.5^3 32hz
Share this post
Link to post
the whine is usually signal ground related, which is unaffected by wire routing.
since you have the whine on both tweeters and mids (but more noticeable on tweeters due to the frequency of the noise) it is associated with HU, RCA's, and amp.
could be the amp itself.
could be resistance between HU ground and amp ground. both should be grounded the floor.
could be a bad connection in an RCA. even new ones have failures.
2014 Accord Sport build log:
My YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
My 1966 MGB Restoration: http://www.mgexp.com/journal/keephopealive
Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
