harse mids from Alpine SPR-60C
ChrisR
Just finished the install of an all-Alpine system in my '11 F150, INA-W910 HU, 2 PDX-F4 4 channel amps, Alpine 10" subs and SPR-69 co-ax rear doors, Alpine SPR-60C components in the front.
Have the system more or less tuned now and the one thing I can't seem to get past is the mid-range on the SPR-60C's in the front. It just seems edgy and harse at times. Depends on the recording. Yesterday I was listening to Allman Brothers Live At the Fillmore East and the lead guitar on a couple tracks was just brutal as far as mids. Using the G-EQ in the 910 HU, I was able to tone it down some, mostly in the 4-8KHz range using a 2db cut. Don't like doing that though. I am thinking of spending the $130.00 or so for the optional Alpine IMPRINT processor which is advertised as a cure for all SQ woes but before I do that, wanted to see if anybody else has experienced mid to upper mid-range problems and what you did about it. I do want to keep my system all-Alpine if possible. BTW, I am using the factory (Ford) wiring to the door speakers; wondering if that may be a contributing factor.
i never use the factory wiring..majority of it is low quality,quite the min..anytime adding an amplifier to speakers..its always best to use aftermarket good/quality 16ga-12ga for the aftermarket speakers..vehicle manufactures get by with min possible/needed to save money
Hell of a deal, I think it may be the last day. If you're considering going to a 3 way, here's a great buy! You have to load them into your cart...
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
I think you need like a 10x switch on an amp? You would need to bandpass the mids or something Pioneer network mode or similar? I know the new...
I have ran the 6.5’s, but not the tweeters. They were very smooth and had good low mid bass. They were perfectly happy being high passed at 75 hz...
ChrisR
ChrisR
central Texas
keep_hope_alive
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
