Alpine PDX-F4 shut down
ChrisR
I just finished the install on my all-Alpine system tonight -- 2 Alpine PDX-F4's, Alpine 910 NAV HU, door speakers are Alpine comps in the front and type-R's in the rear. One of the amps is bridged to run the two subs, the other is running the four door speakers.
System ran fine for couple hours while I was buttoning the truck bak up, putting tools away. Set output levels, some basic audio setting on the 910 HU, then took it for a drive to really push it volume wise. SQ was pretty good, then the amp running the 4 door speakers shut down. No power light. The amp running the subs is still on and working fine.
Checked voltage to the amp with my meter -- OK. Checked fuses -- OK (visual and checked continuty with my meter). Key off, back on, power light on the amp flashes briefly, then turns off.
Wondering if this is the "Alpine Safe Mode" I have heard about. It had plenty of time to cool and wasn't that hot to begin with. I'm thinking it's either a problem with the remote wire or maybe a connector fell off one of the speakers in the doors and now it shuts of because it doesn't see a balanced load (???).
Funny, I thought the one driving the subs would be the problem. Any thoughts or suggestions appreciated.
I found the cause of the problem. It was excessive solder on the ring terminal of the main ground wire to a distribution block causing a poor ground. Apparently only affected the ground wire that branched off to the door speaker amp. I re-did all the wiring using as little solder as possible and both amps fired right up. Live and learn //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
This weekend I will be taking actual pictures for other sites. So grab it before its gone
300
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Umm the sub outputs. It's brand spanking new with an install booklet etc.
499
ChrisR
ChrisR
central Texas
ChrisR
    Apr 13, 2024
    Apr 13, 2024
