I have an MVH-8200 and I'm curious if anyone knows when they actually start clipping?
DMM won't tell you but an o-scope will...I don't own one thoughWouldnt you be able to find that out with an O-scope or MM?
a friend who may own one? and your sig is killer lmao.DMM won't tell you but an o-scope will...I don't own one though
Lol thanks...and I don't know of anyone who owns an o-scope. I've heard that some of their headunits clip at 48 and some at 52 but I don't know under what category mine falls under..the reason I ask is because I have to turn up my gain quite a bit cause the preout voltage is low since I don't turn the volume up that much, and I'd rather play the headunit at max volume and my gain turned down a bita friend who may own one? and your sig is killer lmao.
Goes up to 62 I think. The advertised preout voltage is 4v. I haven't taken the time to actually measure it, thoughwhat volume does it go to? Im about to order the DEH-P8400BH myself, i just figure like 10 before max is usually clean if it goes to 50ish, 28 if it goes to 35 area
Whats ure preouts voltage?
Well personally ide just set 50 for max volume and set voltage with a meter. I recently went from 2V to 8V eclipse and honestly my alpine sounded better! I was running a cd8455 passive fronts and via ipod i really couldnt even get it to sound as good. So ive decided that as long as you can match you preouts to gain setting it dosnt matter. I believe its more about having a good DAC for the format your tunes are in, and a good eqGoes up to 62 I think. The advertised preout voltage is 4v. I haven't taken the time to actually measure it, though
