danger ranger build
RangerDangerV2
st cloud MN
Well I wish I would have taken some more pictures today but I was movin quick to get some work done...
it's not much but it is a start, still LOTS of work to do but it is going along smoothly...
today I ordered my deh p8400 bh, 100 of knu kca, 100 sq feet of audio technix 60 mil deadner, firewall bushings, krystal rca kables, xs xp950, fuses and a few fuse holders... last thing to buy is the alt and few other odds and ends... will post picks next week with everything installed.
You got CCA for an SAZ 3500???
this is how I saw it... either way I am going to need two runs of wire... being that with 1 run of ofc I can only draw 300 amps... but with two runs of cca I can draw 500 amps, 2 runs of cca is cheaper than 2 runs of ofc. I dont need 2 runs of ofc because I wont be drawing 600 amps.
so what the hÉll you waiting for get that wire and rcas installed!!!!
Are you planning on reusing the power pack? If yes cut the wires at the top red arrow only. Connect your new radio harness to the translucent one...
Agree with hispl. TC sounds soft parts were few and far between years ago. If you’re wanting to run two TC based subs you may be better off...
16
646
847
RangerDangerV2
RangerDangerV2
st cloud MN
RangerDangerV2
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
