2 12" kicker cvx old style d4
  • 1
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
354
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
891
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
dutchmaster
dutchmaster
syracuse new york
dutchmaster
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
Latest topics
