external bracing
LuvnThatBass
I like speakers
241
Phoenix
Hello all!
I have a 12" hdc3 sub and the box I have does not have any internal bracing. it was constructed by Fischer Customs (bj) using 5/8" Trupan wood (i think its the ultalite, not too sure though), and I was wondering about external bracing? I know it is not as effecting as internal bracing, but I would like to improve the strength. I do not see any issues or anything right now, but I would image the flex of the box is decent considering the subwoofer and the wood (strong yes, but not too thick...) I have a 2' x 4' slab of 1/2" MDF, can I just add this strategically to the sides to help with thickness and reduce flex? I was also thinking about fiber-glassing all the interior corners and joints, any thoughts on this either?
just do strap bracing inside for the long panels. Won't take up enough volume to make a diff and will make the box stronger. 1 1/2 -2" wide strips of 3/4" mdf glued to the panels.
You can roundover the edges of the braces if you have a router.
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
5
890
Yeah I bet. A traffic jam by where I stay now is when you have to slow down a little to get around some Amish dude in a horse and buggy.
25
3K
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
894
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall...
LuvnThatBass
I like speakers
LuvnThatBass
Phoenix
2RZ-FE
Doxquzme
    Apr 13, 2024
1aespinoza
    Apr 13, 2024
Latest topics
