What noise is this from my subs
Imtjnotu
Me Gusta Edition
13,191
San Diego CA
finally got to power my subs today and i hear this coming from both...no before i start pointing fingers to the guy who sold them to me i wanna kno if this is a connection issue or something.....i dont think its coil rub cause i can push down on the cone with no issues no rubbing......
let me kno what u guys think
lms as in "likes making smoke"? because it looks like it has! J/k nope no exp with those at all just not use to a coil being dark like that, all of mine have looked like a new penny until I killed them then they look like that.
swap in another amp, both subs doing the same thing means it should be some other piece of equipments fault. That being said, I wouldn't put it past tc sounds to let subs through QC that are half glued.
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Imtjnotu
Me Gusta Edition
Imtjnotu
San Diego CA
ciaonzo
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
