FS: (2) Napa batteries
J31Rob
CarTune Netwerk
11,827
Indiana
(2) Napa marine batteries
Like BNIB, used for
$60 + shipping each, $50 picked up for each.
$100 + shipping for both, $90 pick up for both.
Must go UPS or be picked up.
---------- Post added at 01:24 PM ---------- Previous post was at 01:23 PM ----------
These are stored with a battery tender connected. Not just sitting around losing charge. Just //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif.
Are these AGM??
they are 120 AH right?
Are you selling them because you didn't like them, or didn't need them?
Not sure, just some cheapos I bought for temp.
RC is generally double aH rating. So I'd assume they're around 60aH.
I bought 2 Yellowtops to replace them when Advanced Auto Parts had a sweet sale on them.
there lead acid wet cell deepcycle battery's yes that cap will come off and you must mount them right side up they are not sealed.
Battery BCI # : BCI #24DCM
Battery Height : 9 3/8"
Battery Length : 10 3/4"
Battery Voltage : 12 Volt
Battery Warranty in Months : 24
Battery Width : 6 3/4"
Battery CA @ 32 Degrees F : 685
Battery CCA @ 0 Degrees F : 550
Battery Posts Type : Top Post & Side
Battery Reserve Capacity : 120
Battery Weight : 42 lbs
Wet or Dry : Wet
If only there was a napa website with prices on it... or are you needing someone to show you how to subtract 40% from the list price?
961
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
960
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
J31Rob
CarTune Netwerk
J31Rob
Indiana
J31Rob
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
