Jump to content
Recommended Posts
I'm about to do a 4th order through the rear deck of my town car . 2 sundown sa 15's . How much port do you guy's think would be a good start ? Box is going to be 4 cubes sealed...8 ported tuned to 48hz. on 1500 watts . I'm thinking around 120-140 inches of port . Or should I go with more being on 1500 watts ?
Thanks for any help
Share this post
Link to post
Share on other sites
What are your goals?
You dont want anywhere near 200in^ of port. And 8 cubes ported isnt necessary.
:terrible:
Share this post
Link to post
I would stick with 120-140 on the port. Too much and it might be a bit too peaky for your liking
Share this post
Link to post
Yeah, 200in^2 is way too big. Usually if you stay around 1/3-1/2 of the woofer's sd, then you're good. In this case, that would be about 100-125in^2 or port area.
2,500+ designs since March 2011
Share this post
Link to post
another ecellent designer as far as i can tell
yah bro he is i asked him some questions and he got me lined out quick. told me 4 cuft tuning 32. im gonna go get some chip bord and nails tomorrow and build my first ram designs box!
Share this post
Link to post
I'm looking at doing a 6th or 8th order in my town car, any inputs?
[sIGPIC][/sIGPIC]
Share this post
Link to post
Loud and low...daily pounder . I'm thinking like 4 sealed and 6 ported tuned to around 48-50 hz. With like 120 in. of port to start . I'll build it so I can change the port if necessary .
Share this post
Link to post
I was thinking around 120in^2 to start . How's 4 sealed and 6 ported tuned around 48-50 hz. ?
Thanks for the help guys
Share this post
Link to post
You can just throw numbers out and expect superior results. but what i recommend in this case is to listen to McCabe had to say. Same drivers and he went through quite a bit of changing before something was desirable. That kind of experience is fully necessary when dealing with bandpasses rather than throwing out numbers and going with a generic 2:1 ratio.
But for informational purposes, 200sqin can work well if the design allows it to. But the room needed may be quite large. Not to say that certain more complex designs can be scaled but i would not recommend using just a numbered recommendation with the full understanding of the design as a whole.
The great thing about 4th orders, is phase control can be less important than in a combined phase design idea, so generally, if you want to stick with just numbers for designing a forth, it will work......just might not be what you want in the end.
Either way, good luck on the build and i hope it works for you! Keep us updated!
By using a designer, you will get much better results than just, "try this.....".
[sIGPIC][/sIGPIC]
Contact me for more info:[/color][/i][/b]
Mobile Enclosures:http://mobileenclosures.com
Facebook:http://www.facebook.com/pages/Mobile-Enclosures/134158593281463
YouTube Channel http://www.youtube.com/user/TheMobileenclosures
Share this post
Link to post
i dont have near that amount of ported area, but my trunk isnt quite as big as yours either. i went with 100sqinch of port throiugh myvery knoledagble rear armrest, and im happy with it. 1500 watts on 2 sa 15s. 120 would be probubly close to where u need to be, stay within what ever gmonkey has for u on his advice. worked really well for me, and noone else seems to know quite as much about actual results for a 4th order, they just have the programs and software capabilities, which is ok , but for actual results gmonkey seemed to be most helpful
Can u smellllllllllll, what the rock is cookin?!!!
Seen your video's on youtube...nice job . How's it sound now after you made the port bigger ?
Share this post
Link to post
I need to do this in my grand marquis...
Headunit - Stock cassette player - Pioneer P9400
Front Stage - Pyle 8 inch subs (1000 watt peak!!) - Polk DB6.5 (about to be CDT 6.5s)
Rear stage - Deleted (stolen) - Deleted
Sub stage - custom built 15 inch sony xplod (5k watt peak!!!) (huge box) - Two SA12's built by Corey
Sub amp - Pyle 8000w peak!! (spl edition) - AQ2200
Electircal - 35 amp alt from ford festiva upgrade, stolen battery, 28 gauge solder coil for my cable - Dual D34 Yellows, 1/0 trystar OFC, 135amp alt
Share this post
Link to post
Thanks...Yeah I hear ya...don't know till you build it . Build and maybe build again to get the results
Share this post
Link to post
Do it up...
Not sure where to start.. maybe I should just crash it into a dairy queen then buy a tahoe
Share this post
Link to post
Btw, Im the one on FLSPL who gave you the recommendations for 4 sealed/6 ported. My name is Chuck on there.
:terrible:
Share this post
Link to post
Yes.. I know
Thanks man
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
